fuel filter size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2012, 09:12 PM
396chevelle's Avatar
fuel filter size?
Ok, I noticed small particles getting past my 40 micron fuel filter just before it goes into the carb. On the back side I just replaced the gas tank's sending unit and filter. not sure what size micron filter is in the tank! Would you guys recommend a 10 micron just before the carb or is that to small? Basically I have the stock filter in the tank before the Mechanical fuel pump and then after the fuel pump before the carb I have a 40 micron filter. Very fine particles still getting by!
Old 04-01-2012, 11:54 PM
327NUT's Avatar
You must have very good eyes, how do you can actually see these "very fine particles"?
Old 04-02-2012, 07:37 AM
I have a clear fuel filter on the motor and the same small particles "seen" in the filter are the same particles laying in the float bowl! Fine or very fine
Old 04-02-2012, 07:56 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
my first question is
was this all new before you started?
just want to make sure that its not left-over goodies
maybe clean out system and try again to see if it returns?
I thought 40 was the carb standard
and 10 is F.I. standard
what brand/style filter do you have?
maybe you can put a different filter in the housing you already own
there are lots of choices depending on brand/style
35, 25,15,10
Old 04-02-2012, 07:58 AM
I don't understand?
they would have to be, I think a micron, is 1 millionth of a meter
Old 04-02-2012, 10:59 AM
35, 25,15,10
I have a russell brand filter 40 micron in line filter at the carb. It is the old system, but I pulled the tank and inspected and cleaned it really well when I replaced the sending unit and filter! I guess it's possible there was a little that could have been missed being there's limited access in the tank!
Old 04-02-2012, 11:32 AM
Simple, if u take 1 micron it would be hard to see, but let's say u take a 30 micron and group it together with a lot more 30 microns there u go! An accumulation of microns .
Changing the filter in the FRAM HPG-1 fuel filter assembly tombguard Hotrodding Basics 3 08-18-2009 06:24 PM
Looking for a fuel filter cover or a metal fuel filter. Suggestions? (pic) rajsid Engine 3 08-05-2009 07:31 PM
fuel line size to my old filter ratpackin Engine 2 05-25-2008 01:07 AM
fuel injected engine needs fuel filter autonut Engine 3 04-13-2008 08:54 AM
E85 compatible fuel filter, with fuel injection ripple Engine 5 05-10-2007 06:48 AM
