AN Fuel fittings - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2004, 07:28 PM
New Member
AN Fuel fittings
The outlet on my fuel celll is -10an, and my fuel line is 3/8th inch, how can i connect the 2 together?
links would be great
thank you
-Chris
Old 03-31-2004, 07:44 PM
4 Jaw Chuck's Avatar
Happy hunting.
Outlawed tunes from outlawed pipes
Old 04-01-2004, 12:07 PM
malc's Avatar
Born To Be Mild
One of these http://store.summitracing.com/partde...t=EAR%2D991914 and one of these http://store.summitracing.com/partde...t=RUS%2D639200
Old 04-01-2004, 12:27 PM
camaroman7d's Avatar
You have several options. I am assuming you are using a tube nut on the 3/8" tube If so you can either change the fuel cell fitting or you can get a AN reducer. If you do not have a tube nut then, that will be your first step. Once you have that it will depend on if you plan running hard line directly to the cell. If not you will need a union to mate the hard line to the braided line (that is the method I would suggest).
Royce
