fuel float in tank - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-24-2007, 11:06 AM
elcaminodragster's Avatar
70 El Camino aka FRANKENSTEIN
haha thats creepy thats exactly word for word what my dad said a few weeks ago.
shes 22. she is my sis and i love her to death but i just cant stand how freakin lazy she is. im not tryin to make her look bad but she just has no drive to learn about her car that she says she loves so much but rarely even washes it!!! i mean my car is primer and i wash it all the time. she will wash it maybe 3 times a month. i will give her this tho... we have been talkin about what little things need to be done on it (finally after years of needin all what im about to list) such as all around weatherstripping, speedo gear because the speed is off by about 7mph, new headlights and a relay kit for them, new side view mirror, trim clips not the trim just the clips to hold it, new hood locks, and a few more little things. the most expensive thing to buy that is needed is the weatherstripping. so for the past 2 pay checks of hers she been givein me bits of money to put towards her car.
  #17 (permalink)
Old 10-24-2007, 04:10 PM
elcamino,
you may have heard of the book: "Men are from Mars, Women are from Venus" (So True!)
what is a "priority" in your male head....is not a "priority" in her female head....
the items on the list are only "annoyances" to her, not a priority at all....
go do non-car stuff with her and enjoy life and each other....that's alot more important than a leaky door gasket or a wrong speedo
and that's the end of my "counseling session"
  #18 (permalink)
Old 10-25-2007, 04:10 PM
back on the subject
well i know i did somethin wrong because the gauge is still reading full and there is 100miles already drivin since the last filling of the tank. i know the gauge works because i tested it just as all of you said. could i have just gotten a bad float??? there is only one way to install the float and its in there that way. im gonna run the tank dry and pull the float to look at it maybe somethin is loose or bad idk ill take pics when i get it out either today or tomorrow
  #19 (permalink)
Old 10-25-2007, 04:35 PM
It sounds as if the wire (yellow/white stripe) to the gauge is grounded. Take it loose from the sender and the gauge should read empty. Put an ohm meter from the terminal on the sender where that yellow wires goes and check the resistance between it and the tank then between it (the terminal) and a good body ground. Get back to us with those readings and maybe we can figure this out but without those tests it will just be more guess work.
  #20 (permalink)
Old 10-25-2007, 05:20 PM
camino,
just adding to oldred's post....
read the ohms at the sender connect and at the dash harness yellow/white connect with the sender plug connected to the yellow/white....they should read the same "if" the yellow white wire is OK...
or...
do it "hi tech" to prove the yellow/white wire is OK
unplug the sender and the dash harness...use a known good piece of wire jumper hooked to the sender plug and dash plug and compare the guage readings
  #21 (permalink)
ill get to the tests hopefully today but for right now i pulled the float and took some pics everything looks right good and clean. ill put it back in and do the test you asked for oldred.
EDIT: everything on the outside looks good but check out the first pic. it fell off right after i took the pic.
ID:	25083   Click image for larger version
ID:	25084   Click image for larger version
ID:	25085   Click image for larger version
Last edited by elcaminodragster; 10-25-2007 at 05:25 PM. Reason: found something not right with the float
  #22 (permalink)
Old 10-25-2007, 08:40 PM
Return it for a refund or scrap it. You could put it back together and it MIGHT work but do you really want to trust that thing? From the price you paid for it I would have thought you had a good one but that thing looks like one of the "cheapies" I was talking about.
  #23 (permalink)
Old 10-25-2007, 10:32 PM
no im for sure gonna get a refund or exchange it. it seems like its gonna quality made but idk about the one part so im gonna give this brand one more shot. if it doesnt work or it fails then im gonna buy one from yearone ive had nothin but good parts from them on my elky. well thanks for all the help everyone
  #24 (permalink)
Old 10-26-2007, 05:46 AM
WHOA! I apparently was looking at the wrong thing because I thought you had paid well over a hundred bucks for that unit, no? The link you provided only takes me back to the home page now and not the sending unit. If you have that $44 unit (which is only a little over $20 at Mustangs unlimited) then that is the problem. If you get another one just like it you may have it work (or not) for a while but I would not expect it to last long at all.
This is what you need but it is pricey compared to what you have, unfortuantly what you have is most likely what you will get again if you replace that one with the same.
http://www.mustangsunlimited.reachlo...26ei%253DUTF-8
For whatever reason I can not get it to link directly to the part but you need P/N F1947 01
Maybe Red65 knows of a cheaper alternative?
  #25 (permalink)
Old 10-26-2007, 08:34 AM
camino,
since you do have the new sender out...stick the old one back in and compare the guage reading....both senders read full with half a tank of gas...it's not likely the sender
here's my brand choice for a sender.....car specific sender models and well made...$57 for a 68'
http://www.partsamerica.com/productd...rtNumber=FG86A
"check simple first"
roll up a piece of 400 or 600 grit sand paper into a tight small roll and clean the y/w wire female plug at the sender (it's only been exposed to weather for 40 years worth of corrosion)....better yet, cut it off and use a soldered loop connect and a (?) 3/16x24 thread nut...(whoopee, takes 2 minutes longer to remove the nut to pull the tank in order to have a rock-solid wire connect...)
when you are totally sure it is all done and working....last step....smear a dab of grease on the exposed threads/nut/terminal (cotten ear swab works great) so that it will come loose years from now (or sooner when she needs a new tank itself)
  #26 (permalink)
Old 10-26-2007, 12:55 PM
Originally Posted by red65mustang
camino,
im a few steps ahead of you i already cut off the connection and did the loop with a nut on it. some di electric grease and its sittin pretty i would try the old float but its trashed the filter is non existent and the float doesnt float lol.
!!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! islandman Engine 3 03-17-2007 04:36 PM
fuel cell installation 19nova72 Engine 5 11-19-2004 05:36 PM
fuel tank ground friend Electrical 2 09-02-2004 07:20 PM
34 Ford fuel tank question 302 Z28 General Rodding Tech 1 02-01-2004 05:55 PM
Repairing a fuel tank float Jag Daddy Electrical 2 04-05-2003 06:31 AM
