fuel flow rate for stromberg 97s - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2005, 11:52 AM
hi all,
I was wondering if anybody could tell me, what fuel flow rate I need to run 4 stromberg 97s on a 1955 331 Hemi? Also if anybody could recomend a quieter electric fuel pump, I already have a holley blue pump but this is too loud. Does anybody know if carter fuel pumps are quieter than holleys or louder?
thanks
gaz
Old 04-14-2005, 10:13 AM
willys36@aol.com's Avatar
Wiki Edits: 21
CFM rating for popular vintage Stromberg carbs
model 81 => 135 cfm.
model 48 => 150 cfm.
model 97 => 135 cfm.
Ask this guy for more info.
Also, did you know there is a guy making brand new 97s? tech@stromberg-97.com is their tech line and since they appear to have done a serious, scientific reverse engineering job on the carb, they would be able to tell you more that you ever wanted to know about the thing! Here is a solid model of their coming product.
Other references here and here and here.
I run Carter $60 rotary pumps on all my cars. Cheap reliable and I think they are pretty quiet when mounted w/ the supplied rubber isolation bracket and back near the tank but then no electric after-market pump will match the one in Granny and Gramp's Buick LeSabre.
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
fuel cell installation 19nova72 Engine 5 11-19-2004 04:36 PM
New Fuel Pump, but no flow... ??? Dizturbed One Engine 5 11-19-2004 03:42 PM
Flow Rate Data for '487' heads? pgtr Engine 3 09-14-2004 01:20 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
