fuel gauage stopped working - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2010, 12:45 PM
watchdude1's Avatar
I have a 1988 Toyota pickup, my fuel gauage stopped working, I unplugged the wire connection and checked the wires, the 2 side wires have no power and the middle wire has power, but it does no go to the other side of the connection, so I bought and installed a new sending unit. still not working,followed the wires to the computer, then I removed the dash but it is a circuit board, went back to the tank and ran a ground lead from the tank to the frame it wil not work, what else can I do?
why are there 3wires with power in the middle wire and then only 2 wires on the sending unit?
ID:	45777   Click image for larger version
ID:	45778   Click image for larger version
ID:	45779   Click image for larger version
ID:	45780   Click image for larger version
Old 05-24-2010, 09:50 PM
Barry.M's Avatar
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project-For Sale
Wiki Edits: 3
Generally speaking fuel gauges work as follows but original equipment manufactured (OEM) made gauges by companies do strange things.
The power wire (12V middle wire in your case) supplies power to the gauge (wire 1). One wire from the gauge goes to the sender unit (wire 2) in your fuel tank, sometimes via the computer if a late model vehicle. The other wire from the gauge will go to a "ground" (wire 3).
To make matters confusing, many OEM gauges (i.e.factory installed) take the power from a little voltage regulator (not the voltage regulator on the alternator) situated behind the dash somewhere or in the computer box and the other "ground wire" goes back to this voltage regulator also but on the "ground" /negative side. These gauges operate at 8-10V or less. They do this knowing that modern vehicles often operate at lower than 12V battery condition i.e. Aircon on, stereo on, lights on etc. etc.. This is why some gauges fluctuate up and down a bit for no particular reason.
OEM gauges are made like this (thermostatic principle) as they are cheaper to make than aftermarket gauges which generally are of the "balancing coil" type. But I digress.
Now back to your gauge. Once power is supplied to the gauge one wire as discussed goes back to the fuel tank sender and either the sender unit earths out through the tank or a "ground" wire supplies the earth. That is why you have three(3) wires on the gauge and two(2) wires on the tank. The fuel tank sender is in fact a type of Rheostat that "earths out" the gauge.
Checking which one is working or not requires a multi-meter or a known good gauge. Without a multi-meter you are very limited with what you can check. The fact that you've got power at the gauge is step one. Now it's time to buy a multi-meter, they are cheap and very useful if you don't have one. If you don't have one buy a LED display unit. A Good basic one for Automotive work is an 830B sold by many companies under there own brand and you should be able to pick one up for $10-$20.00.
Hope this helps........Barry.
Old 05-25-2010, 02:11 PM
watchdude1's Avatar
Barry:
I have a multi meter the problem is what to do with it,How do I check the fuel gauage when it is a circuit board were do you check, i traced the wires they go into the computer then to the sending unit, I tested the two wires coming out of the sending unit with a tester the light does not light up on either wire one is white with red and other is white with black the ground I suppose,I dont want to put any 12volt source onto these wires going to the sending unit it might blow up the gas tank so what or how do I check there is no power going to the 2 wires on the sending unit. maybe I need to find the voltage regulator ,the truck is pretty rusty and the ground on the tank is rusted out but I ran a ground wire to the tank to the frame with a ala-gator clips it still did not work, so confused what the.
Thanks Tom
Old 06-19-2010, 07:31 PM
watchdude1's Avatar
ok, I removed the instrument panel I checkd the fuel gauage it has 3 bolts, there is a marking which says 7v and ing and fu ,I put my volt meter on the ing and there is 9.50 volts the two other ones have no voltage don't know what they go too I'm thinking one to the computer then too sending unit and other to a ground?
I also ground the metal around one of the bolts on the fuel tank and ran a ground wire to the frame,thinking that the tank might not be grounded good still my fuel gauage is not working,can't seem to find a reguato runder the dash to check, any ideas on what else I can do.
ID:	46297   Click image for larger version
Old 06-20-2010, 08:19 AM
Barry.M's Avatar
Old Phart
Wiki Edits: 3
G'day Watchdude,
OK there are a couple of more things you can check with your multimeter. Unfortunately as I don't have an electrical schematic or vehicle to reference to, it is pretty much guesswork from my seat. The fact that you've got 9.5 Volts to the IGN pole is a good sign. The 7V lead is probably the regulated supply we talked about previously. The FU is probably the sending unit lead. The last unidentified lead could be a ground or may go to the computer to complete that circuit.
Now for some more tests. Switch your multimeter to Ohms something in the 500u to 2000u range. These next tests will determine if you've got a circuit or not and therefore do not require power to be turned on to the gauge or sender. You will be testing what resistance there is in the circuit. No resistance at all, not even a poofteenth means an open circuit or broken circuit.
Disconnect the sender unit wire at the sender. Now place the red lead on the terminal and the other lead to the sender unit mounting plate. You should get a reading of some sort ?. May only be small like 5, 10, 20, 30 ohms or less or as much as 500-600 ?. Yes/No ?. If you get a reading of any kind you've got a circuit, this is good. No reading at all, no circuit, means dud sender. Pull the sender and check over, repair or replace.
If Yes go to next step. Repeat the above except this time place the black lead to a good earth on the chassic. Resistance should now be greater than before ? Yes/No ?. If yes, this is good, how much extra resistance could be a problem, but one step at a time. If No then the ground wire from the tank to earth is broken.
Next step assuming Yes to all tests so far. Switch you multimeter back to a setting that will read 12V. Switch on the Ignition and test for voltage coming down to the tank sender via the sending unit wire. Once again, red lead on the sender wire, black lead to the chassic for a good ground. Got voltage Yes/No ?. Anywhere from 3-10 Volts probably. Yes is good, No means the problem is either the sender wire or further up. Switch Ignition off again.
To test the sender wire, find a long piece of auto electrical wire of similar size to the sender. Switch your multimeter back to Ohms. Check the test wire and note the resistance value. Now attach that test wire to the sender wire, you are making a big loop circuit. Now at the gauge end place the red lead of the MM on the FU terminal and the black lead on your test wire, Any reading ? Yes/No ?. If yes we guessed correctly that the FU terminal is the sender wire and that circuit is good. If Yes, is the reading similar to the tank reading less the noted resistance in your test wire ?. If the reading is MUCH, MUCH higher than before then there is a problem with dodgy connections or frayed wires. This needs to be investigated.
If NO, move the red MM lead to the 7V terminal any reading ?. Yes/No. If Yes then this lead MAY be the sender unit lead. If No, move the red MM lead to the unidentified terminal. Any reading ? Yes/No ?. Ditto previous comments.
If Yes to these tests then the problem is at the gauge end. You can do some similar resistance tests to the gauge but without a wiring diagram you (and I) are flying blind. But what you can test is the resistance of the printed circuits from terminals to the plug where the gauge cluster attaches to the wiring loom.
But at least after these tests you should be able to determine where the fault lies. i.e. at the tank, sender wire, ground, or at the gauge.
I hope this doen't sound too comfusing but once you've done a few tests it will become second nature and will be good experience for future troubleshooting.
Post again with results and maybe I or somebody else will be able to suggest more test options.
Good luck..........Barry.
Old 06-20-2010, 04:04 PM
watchdude1's Avatar
Thanks, Barry
I will give it a shot next weekend, if i have time
thanks again for your time.
Aftermarket EFI ? x007 Engine 61 02-08-2012 10:38 AM
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Nitrous fuel supply ??? 67 Deuce 4 Me Engine 6 11-11-2007 09:30 AM
new fuel pump not working 53LEDSLED Engine 4 08-30-2005 06:48 PM
Hydraulic Jack has stopped working?? HotRodMan Engine 3 06-06-2003 03:55 AM
