fuel gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2009, 11:09 AM
fuel gauge
I PUT A AFTER MARKET FUEL GAUGE IN MY 1980 CAMARO .HOW DO I WIRE IT USEING FACTORY SENTING UNIT AND WIRING
Old 09-07-2009, 11:25 AM
302 Z28's Avatar
Please do not post with your caps lock on, it's considered screaming.
Did you after market fuel gage not come with instructions and a sending unit? If you are trying to use an after market fuel gage with an OEM sending unit you will have to modify the OEM sending unit to the proper resistance the after market gage operates at.
Vince
Old 09-07-2009, 12:16 PM
I'll echo what Vince said. The fuel gauge requires a specific sending unit resistance to operate properly. If you got lucky and happen to have a gauge that uses a sender with the same resistance as stock, you should be able to wire it up using the same wires as stock. If you have a gauge that requires a sender with a different resistance, you need to get the correct sender for that gauge and install it in the tank.
Depending on the resistance of the stock sender and the requirements of the gauge, you MIGHT be able to build a voltage divider circuit to match the old sender to the new gauge.
aftermarket fuel gauge frank88chevy Electrical 1 04-26-2008 07:48 AM
Fuel Gauge Problem...68 firebird SouthernRodder Electrical 2 05-11-2007 05:46 PM
Fuel gauge help dpjim2 Electrical 7 05-27-2006 04:16 PM
fuel gauge wiring flamedfordbronco Electrical 4 07-26-2005 06:46 PM
inline fuel pressure gauge? Jag Daddy Engine 3 05-28-2003 09:39 PM
