Fuel Gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2012, 05:03 PM
Fuel Gauge
1985 GMC 1 gas tank.
(Fuel needle) when tank is full, needle moves
to the extreme right. Went almost empty the
needle movies towards the full mark.
Do you think it might be the sending unit
In gas tank?
Old 03-04-2012, 05:56 PM
EOD Guy's Avatar
sounds like you might have it figured out...... some times it might be a loose connection on the sending unit..... or if the wiring is good you might be able to pull the sending unit and bend the float rod (if it has one) to re-calibrate it
Old 03-05-2012, 12:38 PM
Pull the wire off the sending unit With the wire off and the key on it should read full. Ground the wire and with the key on it should read empty. If it does this you have a bad sending unit If it dosn't do this you have a bad gauge or a wiring problem
fuel gauge roadhogg Electrical 2 09-07-2009 12:16 PM
fuel gauge goshawks00 Electrical 5 01-22-2007 06:56 PM
New Fuel Gauge 73oldsman Hotrodders' Lounge 2 04-25-2006 06:43 PM
Fuel Gauge DoubleVision Electrical 4 11-01-2004 04:38 PM
fuel gauge akm Electrical 3 10-13-2004 07:00 PM
