Fuel gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2004, 09:52 PM
oils65mustang's Avatar
Fuel gauge
I have found that my fuel gauge is faulty. The sender works fine but the fuel gauge does not respond.
Is there a company out there that repairs gauges?
Old 08-03-2004, 10:17 AM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
Are you sure its the gauge? Have you checked the IRV (instrument voltage regulator) on the back of the cluster?
Old 08-03-2004, 04:55 PM
Constant voltage unit
Thanks for the suggestion.
Yes, I check it with a volt-ohm meter and with the Mustang gas gauge dangling from the leads. The Mustang gas gauge indicated level in the tank. The Galaxie gas gauge did not move off empty. I checked voltage and resistance throughout the circuit and the only open was at the Galaxie gas gauge. Not so with the Mustang gas gauge. Continuity was good in the wiring, sender and the constant voltage unit.
My best guess was that it's the gas gauge.
Old 08-04-2004, 01:46 AM
Sounds like you checked ot out properly. Try a copy of Mustangs and Fords, or Mustang Monthly magazines. There should be a advertiser in there for rebuilders of gauges.
