Fuel gauge doesn't work - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2010, 05:36 PM
69Bowtie's Avatar
Need some help!!!!!!! I've got a 69 camaro that has a fuel gauge problem. It shows past full, I've tried a new gauge but it does the same thing. I've checked most of the wiring and it appears that it's OK. Are there any tests I can run without dropping the tank? What are my options?
Thanks
Old 08-06-2010, 01:10 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
I believe if the gauge is pinned theres a short on the sender or the sender wire. I don't know about Cameros but isn't there a harness connector in the trunk area to disconnect the sender/tail lights and such? Disconnect the sender wire as close to the tank as posible and see if the gauge goes down.
Old 08-06-2010, 03:49 PM
69Bowtie's Avatar
Thanks MRTS33, I'll try that.
Old 08-06-2010, 04:49 PM
poncho62's Avatar
Wiki Edits: 5
The ground wire goes from the sender to the car frame has rusted off.......most likely at the frame end......It is usually at the rear in front of the rear bumper
Old 08-06-2010, 05:02 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Thanks
I agree with poncho and would like to add that checking most of the wiring doesn't get it . You need to check ALL of the wiring starting as close to the tank as you can get . If I remember correctly on a chevy ,if the sender wire has gone to ground the gauge will stay on full . If you have lost ground or the wire is broken it will stay on empty .
Old 08-06-2010, 06:27 PM
MRTS33's Avatar
AH yes I forgot about that one.
Old 08-08-2010, 06:44 AM
69Bowtie's Avatar
Thanks everyone for the help.
hydrogen booster / more mpg hottrodz Engine 39 08-28-2008 02:09 PM
69 Camaro fuel gauge diagram... camaro freak Electrical 1 02-23-2008 05:40 PM
Fuel level gauge question mattson70 Electrical 1 02-23-2007 05:50 PM
fuel gauge goshawks00 Electrical 5 01-22-2007 05:56 PM
fuel gauge akm Electrical 3 10-13-2004 06:00 PM
