Fuel gauge not working correctly - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-01-2013, 10:32 AM
life is a temporary assignment
This is what I was meaning..
The fuel sender does produces an (ohm signal). But It is not a 12 volt source, “hot” lead as that could lead to an explosive condition!
So what I was trying to post here was to NOT run a (12 volt source) to the sender unit..
  #17 (permalink)
Old 03-01-2013, 10:56 AM
sedanbob's Avatar
There is no ohm-signal - the resistance in the sender (ohms) reduces the voltage that flows through the sender, and therefore through the gauge. When the sender registers 0 ohms (full or empty depending on the sender), there will be 12 volts coming through the sender and to the gauge. There is no explosion because there is no spark - just like when there is an in-tank fuel pump. They draw a full 12 volts and depending on the unit, a fair number of amps. No spark, no explosion.
  #18 (permalink)
Old 03-01-2013, 06:32 PM
Thanks for putting out the correct information, I had given up.
  #19 (permalink)
Old 03-02-2013, 07:21 AM
EOD Guy's Avatar
Sedan is correct....... no arc or sparks........ no explosion. That is the reason marine alt, starters etc.... cost so much, they have to seal them up.
Petrol gauge not working skylimt Electrical 1 01-02-2012 09:49 AM
Fuel gauge not working... Hwyhogg Electrical 7 11-16-2011 10:52 AM
Gas gauge not working gothrod87 Electrical 4 06-01-2005 08:26 AM
Question about Temp-gauge not working??? Robbie Engine 4 06-13-2004 08:47 PM
