Fuel gauge not working correctly - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2013, 10:06 AM
65 gmc, fuel gauge is stuck on full any suggestions
Old 02-28-2013, 11:08 AM
It's a fairly new sending unit. Only way to get fuel gauge to move is putting a ground on the hot wire. Then the gauge jumps almost to half and then bak to full...wiring problem?
Old 02-28-2013, 11:46 AM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
When the sending unit was replaced did the gauge work OK?
Make sure the sending unit is grounded. Sometimes the rust builds up an breaks the ground path to the chassis.
vicrod
Old 02-28-2013, 11:57 AM
sedanbob's Avatar
Try running a dedicated ground from a clean spot on the chassis to one of the bolts on the sending unit flange. See if that helps.
Old 02-28-2013, 05:16 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
What hot wire ???
The wire going to the tank( sending unit) SHOULD NOT be hot.. Make sure the tank has a ground...
Old 02-28-2013, 06:31 PM
The wire going to the sending unit has to be hot, it grounds through the sending units variable resistance to operate the gauge. Your trucks system should be 0-90 ohm type. If you ground the sending unit wire, the gauge should read zero and stay there. If you connect a 90 ohm resistor between the wire and ground, it should read full. (you probably won't find a 90 ohm resistor, but you can get a 100 ohm from Radio Shack and it will get you in the ball park) This will tell you if the gauge is working.
As has been previously said, you need to make sure the sending unit is grounded properly. If it still doesn't work, you need to pull the sending unit, connect an ohmeter to it and make sure the resistance changes between 0 and 90 ohms as you move the float arm.
Old 02-28-2013, 06:43 PM
How do you ground a hot wire..
Never seen a hot wire going to a sender unit..I have seen a hot feeding the gauge,, But never a hot going to a FUEL sender..
Old 02-28-2013, 06:50 PM
What ever you do.. PLEASE DO NOT !!!!!! run a hot wire to the sender unit..
Old 02-28-2013, 07:21 PM
Maybe we have a misunderstanding here, but the power you put into a gauge comes out of the gauge and goes to the sending unit where the variable resistance causes the needle to move. if you connect a voltmeter to the sending unit, you will read voltage. If the wire is not hot, how is the sending unit going to operate the gauge?
Old 02-28-2013, 07:31 PM
It work's through a ground, Not a hot.. Why do you think when you ground it, It moves the gauge..... You should be very careful posting to the world to run a hot wire to a FUEL sender unit,,, You might just cause someone to get hurt or even worst blown up...
Think of it like this.. Take a hot wire and ground it... You will short it out... The hot only feed's the gauge,, Not the sender,,, The gauge doesn't work until you make a ground.. The sender makes and breaks the ground,, That's why the tank needs a ground for the sender to work right..
I see now how you came up with the name sparkchaser...Fun intended..
Old 02-28-2013, 08:40 PM
I never said to run a hot wire to the sender. I said the wire coming from the gauge is hot, it has voltage on it. Pull the wire off your sending unit, connect a voltmeter to it and you will be amazed.
Old 02-28-2013, 08:51 PM
Look's like you said it here..
That would be post #6
Old 02-28-2013, 08:56 PM
Here's something you may need to read when you have time...Pick one..
Google
Old 02-28-2013, 09:14 PM
Here's a good write up...The GM Fuel Gauge Mystery 1965 & Newer |
Old 03-01-2013, 08:51 AM
sedanbob's Avatar
When the ignition is on, and your gauge is reading (full, empty, half way, doesn't matter) current is flowing through the sender. Yes, the sender is on the ground side of the gauge, but if there wasn't current flowing through the sender you wouldn't get a reading. As was stated earlier, if you put one lead from a volt meter on the lead going to the sender, and the other lead going to a ground, you will measure voltage. The sender body is in contact with the tank, which is in contact with the frame, thereby grounded - but those connections may not be electrically clean. If you jump a wire from a bolt on the sender flange, to a clean spot on the frame and the gauge then works, the problem was a poor ground.
Petrol gauge not working skylimt Electrical 1 01-02-2012 08:49 AM
Fuel gauge not working... Hwyhogg Electrical 7 11-16-2011 09:52 AM
Gas gauge not working gothrod87 Electrical 4 06-01-2005 07:26 AM
Question about Temp-gauge not working??? Robbie Engine 4 06-13-2004 07:47 PM
