fuel gauge is pegged to FULL!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2010, 01:10 PM
I am replacing my fuel tank and thought this would be the perfect time to fix the fuel gauge. I removed my sending unit and it was corroded. I ordered a new one and am still waiting for it to come in. Ive heard the needle can be pegged because the gauge needle is stuck or because there is a wiring problem. What can i check to make sure the wiring is good before in install the new sending unit? I have a 74 nova.
Old 09-16-2010, 02:54 PM
T-bucket23's Avatar
Wiki Edits: 26
make sure the ground wire is still attached to the frame. This is a common issue
Chet
Old 09-16-2010, 03:13 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I would check the wires first. As stated could be the ground wire.
Or just a bad sending unit. JMO
Cole
Old 09-17-2010, 10:28 AM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
Sounds like the sender wire is shorted out. Check to see if there is a bare spot on the wire that is shorting out.
Old 09-17-2010, 03:54 PM
35terraplane's Avatar
Just hook the wire up to the sending unit, make sure the ground wire is grounded good, move lever up and down if needle moves, wire and gauge are good, cut sender float to fit if it 's not the right length and install. If when you move the float up and down check wire with an ohm meter if that checks good the needle is either stuck or the gauge is junk.
Later 35 terraplane
Who hates NHRA's 12" rubber line rule? 454headache Hotrodders' Lounge 21 08-17-2010 07:48 AM
chevelle fuel gauge stays on full? Help! lngliv3 Electrical 8 05-28-2010 09:05 PM
2005 Mustang GT Temp Gauge pegged at 0 75gmck25 Electrical 5 03-28-2010 05:18 PM
Grounding a gas tank and a fuel gauge question Z-Money Pit Electrical 10 06-26-2006 09:53 PM
fuel gauge wiring flamedfordbronco Electrical 4 07-26-2005 05:46 PM
