fuel gauge problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2011, 03:10 AM
fuel gauge problem
i purchased a set of billet gauges from brothers trucks for my 1949 chevy pick up. for some reason when the ignition switch is turned on the gauge pegs out. i can disconnect the ground and it will not peg out, but will not change when i move the sending unit up and down. the sending unit is new also and it works according to my ohm meter. i got another gauge from brothers and it did the same thing. does anyone have any ideas.
thanks
Old 10-18-2011, 03:56 AM
EOD Guy's Avatar
I assume you are talking about the fuel gauge...... that being the case, some fuel gauges work by: one side of the guage is hot the other side goes to the sending unit, not ground, the sending unit is grounded...... as the float moves it changes the resistance and the needle moves etc..... There might be a ground on the gauge but that's prob for the illumination in the gauge.
Old 10-18-2011, 04:59 PM
dilligaf's Avatar
fuel gauge
Make sure that you are using a compatible sender for the gauge that you are using.
Fuel Gauge Problem Centers Electrical 3 05-30-2011 04:39 PM
Fuel Gauge Problem RolandD Electrical 2 06-21-2008 05:54 PM
Fuel Gauge problem slickstick56 Electrical 1 03-13-2006 02:01 AM
Fuel Gauge Problem crash Electrical 4 12-11-2005 08:06 AM
Fuel Gauge problem Bruce Doss Electrical 0 10-20-2005 08:00 AM
