We're winning the case!
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 10-20-2005, 08:00 AM
Bruce Doss Bruce Doss is offline
Fuel Gauge problem
I have a 1995 Cadillac fuel injection LT1 engine and I'm using a 1995 Camaro gas tank with the fuel injection pump and sending unit in the tank, just like it came from GM. I cannot get my fuel pump and gas gauge to work at the same time. I am using TPI gauges. I know the ground from the gauge needs to connect to the sending unit ground and with this connected, the gauge works fine but the fuel pump will not work unless I connect the tank/pump ground, same wire, to the frame. With the ground attached to the frame the gas gauge pegs to 'full' even with very little gas in the tank. When I purchased the Cadillac parts I also got the tank and it has 4 wires coming from the Pump Unit but this tank was too big so I'm using the Camaro which appears to have 3 wires, at least the part I can see, coming from the pump unit. I need to know if the Camaro actually has 4 wires and both grounds have been connected at the unit or what I can do to fix the problem. Thanks so much for any help. Bruce
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Fuel Gauge problem"
Temperature Gauge Problem draft Electrical 4 08-30-2004 10:34 PM
fuel pressure problem? catscan4free Engine 2 02-24-2004 04:50 AM
Replacing fuel gauge sender question? Jag Daddy Electrical 23 10-23-2003 11:55 PM
Fuel Problem matts69camaro Engine 1 01-03-2003 06:04 AM
Fuel problem Bayfrog Engine 2 10-24-2001 01:04 AM
