Doc here,
Remove your sender wire from the tank. Depending on how wired, It will pin the gauge at full or empty (usually full) with no sender...Then ground the wire, It will have the opposite effect, If that is the case your gauge works. Check or repair the sender at the tank. First try a ground jumper to the tank itself, This is usually the problem, If it operates properly, then add a ground strap from the frame to the tank inlet and filter screen access door on the top of the tank (where the sender and fuel lines go in tank) Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Doc here,
Yup, Sounds that way to me too..unless that has an instrument regulator, look on the schematic for that. Doc
fuel guage problem
Doc, I found a blown fuse again, and replaceing it made the guage move, if this means its a true reading or not I don't know.
I tryed unpluging the sender and the guage pinned to past full, grounding the sender did nothing. when I plugged the sender back in , it returned to the reading before I started and the fuse is still good. I will have to drive it and see if the level goes down and then I guess that will mean everything is working properly. Next I will have to find out whats blowing the fuse. Thanks for your help, Bob Last edited by crash; 12-11-2005 at 10:21 AM. Reason: correction |
| Temperature Gauge Problem | draft | Electrical | 4 | 08-30-2004 10:34 PM |
| fuel pressure problem? | catscan4free | Engine | 2 | 02-24-2004 04:50 AM |
| Replacing fuel gauge sender question? | Jag Daddy | Electrical | 23 | 10-23-2003 11:55 PM |
| Fuel Problem | matts69camaro | Engine | 1 | 01-03-2003 06:04 AM |
| Fuel problem | Bayfrog | Engine | 2 | 10-24-2001 01:04 AM |
