Fuel Gauge problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2006, 01:02 AM
Fuel Gauge problem
I have a '56 Chevy car that the gauge acts erradically when the engine is at highway speeds and sometimes at lower speeds. The gauge bounces quickly back and forth rapidly from empty to full. I have noticed that if I push on the dashboard, (anywhere, not just the speedometer portion) the gauge goes back to the tank level, but when I quit pushing on it, it goes back to bouncing... I am afraid that the bouncing will eventually ruin the gauge. I have tried grounding the dash, but it doesn't work. Any ideas? Help!!!
Old 03-13-2006, 02:01 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Ground the gauge to the dash board or suitable hard ground.
The gauge has a terminal for ground this is the one that you want.
You may want to check and clean all grounds while your in there.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 03:35 PM
fuel pressure gauge install help!! Typhoon#691 Engine 1 09-11-2005 08:57 PM
Temperature Gauge Problem draft Electrical 4 08-30-2004 10:34 PM
Replacing fuel gauge sender question? Jag Daddy Electrical 23 10-23-2003 11:55 PM
Fuel problem Bayfrog Engine 2 10-24-2001 01:04 AM
