Fuel Gauge reading wrong
My 32 Plymouth with SBC power has Classic Instruments in dash. Fuel gauge reads between one-quarter and one-half tank of fuel all the time. I know the tank is full but still reads between 1/4 and 1/2. It was same way with previous gauge that I replaced. I have checked grounds, power, sender, wiring, and have even hooked up another sender (holding it in my hand and moving float up and down) as test and still get the same reading. I am baffled. Anyone have an idea what is causing this odd reading in my fuel gauge?
Thanks. 34jeff |
check the vendor
When I bought gages a while back I remember there are different ohm ratings from different companies for the sending units Call classic and check to see if you have the right one.
Classic Instruments make 6 different gauge resistance ranges to match several different OEM senders and an aftermarket gauge/sender set.
You will need to determine the resistance range of the your sender to see if the gauge is matched. I expect the gauge is marked with the resistance range. Such as; 0-30, 0-90, 16-158 ohms. Stroke the sender from full to empty and measure the resistance with an ohmmeter. Some sender/gauge sets read low to high ohms and some high to low ohms. More info is on www.classicinstruments.com . Click on the tab - gauge information then types of gauges then fuel gauges and tank senders. vicrod |
| Fuel Gauge Problem | RolandD | Electrical | 2 | 06-21-2008 05:54 PM |
| aftermarket fuel gauge | frank88chevy | Electrical | 1 | 04-26-2008 06:48 AM |
| 69 Camaro fuel gauge diagram... | camaro freak | Electrical | 1 | 02-23-2008 05:40 PM |
| Fuel gauge problems | 1969NovaSS | Electrical | 5 | 05-04-2006 11:42 PM |
| Fluctuating Fuel Gauge. | Everett II | Electrical | 1 | 04-28-2006 02:20 PM |
