Fuel gauge repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2012, 06:49 AM
Last journal entry: GTO
Fuel gauge repair
67 GTO fuel gauge not working anybody ever rebuild one, or should I jus replace it?
Old 11-17-2012, 08:38 AM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Probably easier for you to replace it.
Did you test it to be sure the gauge is the problem?
If the coils are bad , they can be re wound, but you need the same size enameled wire, and the correct length as it has X ohms per foot, and resistance is the key to accurate operation.Also you need to make a note of the direction of the way it was wound, and how, as far as it is wound, how each stack of windings starts, either at each end or has a transfer style wind etc that starts the next layer at the same end etc.
Fact is stranger than Fiction
Old 11-18-2012, 09:04 AM
What are the symptoms and what have you done?
BB
Old 11-20-2012, 09:30 PM
Test light at tank reading 12 volts, sending unit showing good with omh meter and grounds good, reading good at gauge but gauge shows full all the time, maybe stuck shows full at all times even with out power.
Old 11-21-2012, 01:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
No ground = gauge reading full scale. Might want to take another look.
Good luck.
Fuel Sender Repair PAS55 Electrical 2 12-14-2008 08:02 PM
Help with fuel gauge chewyscool Electrical 4 11-13-2008 04:56 PM
Fuel gauge? rj440 Electrical 5 08-14-2007 08:27 AM
gauge repair parts 55 dude Electrical 1 06-19-2007 09:19 PM
Fuel Gauge DoubleVision Electrical 4 11-01-2004 03:38 PM
