Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel Gauge Sending Unit
Old 02-01-2006, 03:11 PM
3bytheknee's Avatar
3bytheknee 3bytheknee is offline
If you bought TPI-TECH gauges the fuel gauge will have a 240-30 ohm rating. If you bought a fuel cell with foam from Summit the tubular sending unit will most likely be a GM or Ford compatible ohm rating. It took some time for me to find the right sender but JEG'S has them. That's . Summit did not carry the right sender.
