Fuel Gauge Sending Unit
:) If you bought TPI-TECH gauges the fuel gauge will have a 240-30 ohm rating. If you bought a fuel cell with foam from Summit the tubular sending unit will most likely be a GM or Ford compatible ohm rating. It took some time for me to find the right sender but JEG'S has them. That's http://www.jegs.com . Summit did not carry the right sender.
| All times are GMT -6. The time now is 10:53 AM. |
