fuel gauge still full - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2009, 01:33 PM
I dropped the tank and ran a grnd wire from a center brass term in the middle of the sender ( I figured that was the grnd term) to the body. The connection at the body was bare metal. Put the tank back up with no gas in it turned on the key and pegged the gauge. Maybe that center terminal is not a grnd terminal? Should I have connected the wire to a sender mounting screw? Thanks Joe
Old 11-08-2009, 02:27 PM
boatbob2
gas guage.......
Hi ,YES that brass threaded part is for the line to the guage. use a screw that holds the sender into the tank,and run your ground wire to the chassis.
Old 11-08-2009, 04:01 PM
Yes, what boatbob said about the center terminal is for the sender connection on the gauge.
I would suggest running a ground wire all the way from a sender mounting screw to a ground connection on the gauge.
Old 11-08-2009, 04:40 PM
Damm, I had it wired completely wrong. There is a spade connector on the sender that should have been wired to grnd, not the gauge. Thanks, Joe
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 03:35 PM
fuel pressure gauge Jerry-64 Chevelle General Rodding Tech 3 01-15-2008 12:26 PM
Guages are dead gtipton Electrical 4 05-09-2007 09:14 PM
Fuel gauge problems 1969NovaSS Electrical 5 05-04-2006 11:42 PM
Fuel system q, dry at the carb, but fuel bows full? killerformula Engine 6 09-18-2004 06:07 PM
