fuel guage - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2003, 04:00 PM
NAIRB's Avatar
Post fuel guage
I am working on an 80 model chevy pickup. The fuel guage would not read correctly. I bought a used diesel guage for five bucks and stuck it in, but it does not register correctly. When the tank is empty it shows a half tank. When the tank is full, it's completely off of the scale.
Anyway, to make a long story short, I switched resistors to no avail, and put the old guage back in. Now it works fine. Was it just stuck? If so, is it likely it will do it again?
Old 04-24-2003, 07:03 PM
Post
Maybe the ground was loose and your re-installing it made the ground connection tighter. Could have a float that is soaking up some fuel too. I also hook up my ohm meter to the sender and move the float arm through it's travel while watching the meter to test it.
