Fuel Guage Reading wrong - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2004, 03:52 PM
billg_69gmc's Avatar
Last journal entry: Dateline Dec. 2004
I replaced the circuit board on my dash... 69 gmc.
Prior to replacement, all ok... I was having problems with some of the instrument bulb contacts. Now I put the new circuit board on and my fuel guage reading went off the chart... Did I touch something or am I missing something. It seemed fairly idiot proof... or is it?
thanks in advance...
and I did try to search before asking
billg
Old 11-21-2004, 05:45 PM
milner's Avatar
did the gauge go past the full mark, if so , check the wiring connector or the gauge connections. probably a bad ground.
Old 11-21-2004, 09:35 PM
fuel guage
Yes, it was way past full...
empty to full usually shows from say 10 oclock to 2 oclock in degrees... it was at about 4:30 and should have read about half tank... 12 oclock.
Not sure how the ground would be bad...
I will check ground.. thanks a bunch!
billg
Old 12-11-2004, 05:09 PM
fuel guage continued..
Follow up to finding my shorts!
I pulled the instrument panel, check my circuit board (its really more of a sheet) and could find no problems or rather solution.
I went so far as to install the old circuit board and it showed the same problem (short) which caused the fuel gauge to read at the 3 o'clock position.
Is there something I'm missing... the new circuit board is fresh, no tears, scratches etc.
Did something possibly happen to the guage?
What sort of tests can I run with a multimeter?
If it is shorting and I only replaced the circuit board should I also be looking at other things to confirm it's the circuit board.
I'm no genious with electrical, but can follow directions well enough...any help is greatly appreciated.
On a side note... Has anyone ever "fixed" a broken vent flap that is inside a deluxe heat system from a 68-72 chevy. I tried purchasing one, but it seems that everyone is out of stock on it... not to mention it's a $80 piece of plastic!
thanks...
Bill G
