Fuel Hardline project: Braze on T-fitting? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2013, 03:14 PM
Hi Guys, Iím not really a hot rod guy, but the more I look for parts for my various ideas for my project the more links to the hotrod community I come across. So here I am, the project is a '71 bmw 2002.
Iím looking for a braze-on T-fitting that accepts 5/16 (8mm) hardline. Theyíll be used on a Fuel setup for triple weber carbs. Similar to the T-fitting found on the fuel line setup in the picture. If not, any ideas would be appreciated.
Old 04-11-2013, 07:45 PM
sedanbob's Avatar
This is the only site I found that has steel braze-on fittings - it says they are available in 1/16" increments (like A/N fittings - 5/16" = -5). I don't know where you go to buy them retail, but they have contact information - perhaps they can tell you. Good luck.
Old 04-11-2013, 09:03 PM
vinniekq2's Avatar
Why not flair the line and use a threaded "T"
Old 04-11-2013, 09:21 PM
KA67_72's Avatar
I would use one of these from Swagelok. It's 1/4. Drill it out to 5/16.
</title> <meta name="keywords" content="" /> <meta name="description" content="" /> <meta http-equiv="expires" content="0" /> <meta http-equiv="pragma" content="no-cache" /> <script type="text/javascript"> var _gaq = _gaq || []; _gaq.push(['_setAccou
$22
Kevin
Old 04-11-2013, 09:46 PM
Thanks Bob, but I don't see a link. Ido have resale info and all that, so im very interested in hunting them down. Thanks!. Vinnie its admittedly an aesthetic preference In this case. Kevin thanks for the link... will expand the search into 1/4 inch an an possibilities. Will be sure to post finished project pics!
Old 04-11-2013, 11:28 PM
sedanbob's Avatar
Brazetyteģ Stainless Steel Tube and Hose Fittings
Sorry I messed up the link. Here it is.
? on a FAST efi fuel pump # 30085 inlet fitting supercab78 Hotrodding Basics 2 04-05-2013 09:46 PM
1/2 hardline to 3/8 for hvlp question Mach1460 Body - Exterior 5 07-08-2011 12:23 PM
Fuel Tank fitting DrBee Hotrodding Basics 2 07-11-2010 10:32 AM
stainless steel hardline? superdave013 Suspension - Brakes - Steering 13 03-09-2010 06:05 AM
T fitting fuel tomthecomic Engine 1 09-28-2008 07:30 AM
