Fuel Injected 358 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2009, 09:12 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
TPI Fuel Injected 358 sbc
So i got a bunch of parts laying around and want to do another build. I have a 350 short block with speed pro pistons flat top 5cc (.040 over), stock rods with arp bolts installed, and stock crank. I also have a fuel injected TPI intake from an 86 camaro that i have been wanting to use. If i put a set of 882 heads cr approx 9.5:1 and a flat tappet towing/RV cam in it, would the intake work? I know its a lower rpm piece so i figure if i stay with a cam designed for low rpm torque i would be ok. All input appreciated.
Old 10-08-2009, 11:18 AM
Listen and Learn
Wiki Edits: 7
For engine management would this work: http://www.summitracing.com/parts/HL...1/?image=large. I noticed its for speed density, my intake is mass air, is there anyway to convert my intake to speed density?
Old 10-13-2009, 12:50 AM
Siggy_Freud's Avatar
That intake will work with Speed Density. All the speed density requires is a vac port. Instead of having a MAF off the throttle body, you can put a cone filter right off the snout. As I mentioned in your other post, learn to use the stock computer, and save that money for an aftermarket intake. They were designed for a 305. For a cam, use one of the TPI designed cams from a company called TPIS.
I went from a 'towing' cam to one of theirs and the response was great. Good idle behavior, but a lot more torque and grunt.
http://www.tpis.com/index.php?module...t%2FValvetrain
Bringing history and technology together.
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 09:12 AM
SBC fuel pump not working? rolrandy Hotrodding Basics 22 12-07-2007 07:53 AM
fuel injected sbc improvements? DR132 Engine 10 11-28-2007 12:59 PM
Fuel problem on sbc ARRGH agent spliff Engine 15 10-24-2007 06:48 PM
Revamping Fuel System topdogger Engine 6 12-29-2006 12:13 AM
