fuel injected engine needs fuel filter - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2008, 08:57 AM
I have a 1998 Plymouth Grand Voyager with a 3.3liter fuel injected engine.
I want to replace the fuel filter. The Chrysler service manual explains how to depressurize the fuel system before installing the filter. However, after the filter is installed the fuel system must be pressurized again. The manual doesn't give an explanation on that. How is this done? Do I need special tools? Thanks
Old 04-13-2008, 09:03 AM
MT71c-10's Avatar
too many toys,not enough money
Last wiki edit: Garage heating Last photo:
Wiki Edits: 13
turn the key to energize fuel pump. should be all
Old 04-13-2008, 09:07 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
You may have to cycle the key several times to build up enough pressure to start. The fuel pump will run for 2 seconds with each cycle.
Old 04-13-2008, 09:54 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You de pressurize it so it won't squirt or spray fuel all over as you take the filter loose. After replacing the filter it should pressurize itself when you start it up.
fuel filter (Best Place) to install 39chevy Engine 3 07-31-2006 09:05 AM
fuel filter location (or filters) Quick7t2 General Rodding Tech 5 07-04-2006 01:57 PM
fuel injection turned into a carb engine schuffman Engine 3 02-28-2006 02:13 PM
Shelby 427 Alum. Fuel Injected Blower Stroker Engine mustangwizard Introduce Yourself 2 01-10-2006 10:15 PM
Carburator Terrano Engine 10 08-07-2004 12:22 PM
