There is a kit for cleaning injectors. It is "involved", more than just pouring something into the tank. You have to disconnect some sencers, fuel supply,etc.
If you can find a BG product supplier, they have a good cleaner and other lubricants.
How much does the involed systems run and what is involved, I want to clean the injectors on the donar car I am using before I pull it for my project just one thing to eliminate that might go wrong. Also my Dodge Cummins has 250,000 on it and I would like to find a way to clean the injectors with out pulling them.
Oh golly! Don't hold me to it, but I think around $30.00. I was watching the guys on "Shade Tree Mechanic" on TV They were demostrating it one Sunday. Those are the guys who have every tool they need, never get greasy and nothing ever sticks, braks and always fits perfectly.
[quote]Originally posted by Ted655:
<strong> Those are the guys who have every tool they need, never get greasy and nothing ever sticks, braks and always fits perfectly. </strong><hr></blockquote>Yeah I need to borrow some of their luck. I have never had something not take more time than I thought it would. At least I get to learn and make up new cuss words when I am working on a car. Speaking of which one time they showed some outtakes on Hot Rod TV(or whatever it is called now), and man you should have seen this one piece give them all kinds of fun. |
An Injection Service consists of an aerosol or shop air introduced solvent directly into the fuel rail after disabling the car's fuel supply so that the car runs only off the solvent until depleted. This service is not so much for the injectors as ridding the combustion chamber of carbon buildup. There also is a service in which solvent is srayed into the intake manifold(s) to rid them of carbon deposits (from intake flow reversion). It usually costs around $69.95 in this area just for the injection service.
If you are concerned with only the injectors themselves, you can have them flow tested and calibrated on the bench or bite the bullet and go up one size (19lbs. to 22lbs.) cheaply with injectors from a supplier such as ACCEL. |
Thanx again Kulz This is my first conversion with the EFI and I want everything to be correct on the donar car before I pull the motor out to put in my project. Still wateing on the Manual from Ford Racing for the EFI wiring, you have been a big help.
