Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fuel injection question
Old 05-26-2004, 07:03 PM
chianesi's Avatar
chianesi chianesi is offline
Never Give Up
Its common knowledge to check the fuel pressure regulator after installing the gauge and checking the pressure, if it's not to specs. My apologies for not putting it in the last post. But if you read on you'll see that I meant replacing the pump as a last resort. Thanks!
