Thanks guys,I replaced the fuel pressure regulator when I got the car.I saw it run(if you want to call it that),at an idle it blubbered and carried on like it was getting way to much fuel.After replacing the reg.,it didn't want to start at all,the timing was screwed up,half of the plugs had fuel blowing up past the porcelain.I set the timing right,put in new plugs,and still nothing.i pulled the valve covers and checked the lift at the lifters,it was way below specs.Put in new cam,lifters,timing gears and chain.Now it trys to start if I open the throttle about half way,but it will only run for 2 or 3 seconds.If I pop the shrader valve on the throttle body,I only get little more than a trickle of fuel.
