Fuel injection question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2003, 06:39 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Question Fuel injection question
Hello.
Thinking about maybe putting a fuel injection setup on my 500ci Caddy engine when(and if) I ever get it done.
I found 2 that may fit the bill, but need some explanation on em.
1. Is the Holley Cammander 950 4bbl digital fuel injection system. Its 1399.99 complete for the 450-575 horse kit and is a ECU unit?
2. The other is the 1000 cfm Commander 950 system. The universal is from 1434.99 for the 1000cfm mpi kit and 1974.99 for the 2000 cfm mpi kit. Not sure which I would need?
Which setup would be best? Whats the big diff in MPI and ECU? Are they worth a crap? Tnx, HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 01-16-2003, 10:48 AM
deuce_454's Avatar
Post
fuelinjection is a hard one to answer, you can get a SDEFI setup that drives 8 injectors and runs a distributor for arround 650 US, There is a french sysyem called sybele that can run eight injectors, bank to bank, and wasted spark ignition, and that system is about 750 US, all you would need then is the 75-78 efi manifold of a 472/500 caddy, it allready has injector bungs etc and with porting etc. you should be just fine, that is about the cheapest way to go.
Alternatively you have to fabricate a manifold with one, or even better two plenums (that way you can make a hemholz resonator to add horsepower) and add two latemodel mustang throttlebodies and weld in some injectorbungs and make a fuelrail etc. its all within your abillities and all it requires is time. you can mail me at jakob@regeur.dk and i can help you out with the hemholz/ tuned runner length. (sorry kultuz, its just that this is actually real mechanical engineering)
anyway keep us posted on developments
