fuel injecton - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2008, 05:34 PM
fuel injecton
Some Help Please,
I recently swapped the 305 for a Goodwrench 350 in my 1983 GMC Sierra Classic. This vehicle has the Rochester E4ME in it. I want to put fuel injecton on this vehicle. Can I use after market products or do I need to find a newer truck and use it's injection setup? Or am I just way off base with all of this? This is a California vehicle, so is any of this even possible. Any and all help appreciated.
Old 07-12-2008, 06:12 PM
the aftermarket option will be easier but will also be more expensive....you should see if there is a Holley Commander system for your motor....i'm sure there is since it's a 350
Old 07-12-2008, 06:18 PM
Hey,
Thanks for the reply. Isn't that the two barrel system that uses the stock intake, or is it the complete setup with the blower type air plenum? I remember that one was around 3 grand and the othe less than 1 thousand. I can always save up for whatever works, I want to know if there will be issues when time comes to smog.
Old 07-12-2008, 06:26 PM
the one that I've always seen is a MPFI system....I'm sure there are all different kinds of systems avalible tho, especially for sbc's
I am not knowledgable of the emissions laws in California tho so I can't help ya
Old 07-12-2008, 06:34 PM
Ok, that is the one with the manifold and and big plenum. I need to talk to a referee, but they are few and far between and it seems as if you need an appointment to just see one. Thanks for the help
383 SBC, need input for performance issues roxanne68 Engine 24 08-08-2007 11:06 PM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
Fuel Filter Location leejoy Engine 7 05-04-2006 08:50 AM
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
fuel cell installation 19nova72 Engine 5 11-19-2004 04:36 PM
