Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fuel injector code
Old 05-24-2012, 04:42 PM
LATECH's Avatar
LATECH LATECH is offline
That was an injector code for injector in cylinder number 1.
Probably needs a new injector. Seen it before , did it yesterday.
Check the wiring over well. The injector can be ohmed out but wont allways give a reading that is indicative of being faulty, but it can . It can be bad and still read OK when checked. Problem is most likely intermittent, but the ECM is catching it.
I would change the injector on it.
Just curious. How do you know the injector is spraying fuel ?
Fact is stranger than Fiction
