Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fuel injector code
Old 05-24-2012, 06:32 PM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: GTO Reproduction Hood
That is good info RichieHD . I have seen injectors cause an issue like he is describing, but I understand and agree with what you are saying.I was not aware of a service bulletin for the false codes.
I did suspect other issues as well, hence the suggestion for a compression test.
Its allways good to have other opinions, and in this case good factual info, , like a tsb for the injector codes.
Fact is stranger than Fiction
