Fuel injector ohm specs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2008, 11:59 AM
briansansone's Avatar
4 chevys and a ford
My throttle body injectors are both reading 2 ohms of resistance.
They should be between 1.3 - 1.5. How critical is this spec? can I run
these injectors, or replace?
Old 08-18-2008, 02:28 PM
Shelby1's Avatar
Steel Dreams
Brian,
Did you zero your meter with the leads touching each other?
If not zero it with the leads touching and wiggle all the connections that the leads make then retest the injectors and see what you get. You should be able to run them with no problem.
The meter should read .000 on the lowest scale with the leads together.(or close to it!)
Kenny
Lost your job yet?
Keep buying foreign.
Old 08-18-2008, 02:50 PM
hands down,contact Jon at www.fuelinjectorconnection.com
he does wonders with the injectors he has cool videos and stuff to show you
he has solutions to everything,you won't regret !
and his customer service its the best !
Please check this thread with amazing test and videos :
Very interesting !
http://forums.corvetteforum.com/show....php?t=2104010
Old 08-18-2008, 06:26 PM
4 chevys and a ford
No I did not realize I needed to zero the meter. I did think it was quite a coincidence that both injectors were out of specs at exactly the same
resistance. I'll recheck tomorrow when it's light.
Thanks!
E85 105octane pump gas Race Fuel Rob_E85 Engine 46 11-22-2007 12:55 PM
383 SBC, need input for performance issues roxanne68 Engine 24 08-08-2007 11:06 PM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
fuel cell installation 19nova72 Engine 5 11-19-2004 04:36 PM
questions about fuel system for a 434 small block chevy tony350ss Engine 4 08-27-2003 11:02 AM
