fuel injector switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2003, 12:45 PM
does anyone here know if I am able to switch my fuel injectors, 1997 F150 4.2L, stock 19 lb injectors for a set of 24lb injectors with out screwing any thing up?
Old 07-07-2003, 02:04 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Yes, but why do you think you need to?
Old 07-07-2003, 04:36 PM
Cleaner, if that is all you are going to do, then you will not like the results. The bigger injectors need higher fuel pressure and of coures it needs the correct computer inputs to tell them how long to stay open. Basically it is like putting in much bigger jets in a carb and start dumping in a lot of gas. You will not like it!!
Trees
Old 07-07-2003, 10:16 PM
the reason i was going to go with bigger injectors was because i had found a great deal on the 24lb injectors and I had to replace my old ones. thought if there was nothing else that had to be done to put thm in than i was going to do it.
Should stick with 19 than , eh?
Old 07-08-2003, 09:44 AM
here is the product number for th injectors that are on my ford. CM 4785. Does anyone here for sure know if this is 19lb injectors? The parts guy at the dealership could not tell me for sure. Its just when i have been searching the web looking for replacments no 19 lb injector list they are for the 97 f150.
Old 07-08-2003, 11:50 AM
FoxThunder 5.0's Avatar
i think its broke...
yes i believe they're 19 lb
