fuel injector vs 4- barrel carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2011, 07:42 AM
I have been thinking of putting a tuned out fuel injector in my 85 trans am instead of the usual 4- barrel carb...........
so my question is what is the pros and cons of both
Old 02-01-2011, 09:36 AM
Last journal entry: 50 Ply wagon
Main difference is getting the ECM for the injection. You also have to put in an 02 sensor in the exhaust and a return line for the fuel along with an inline high pressure fuel pump. It is not a hard swap but it is time consuming and making sure the ECM matches the injection and getting the wiring done properly.
The benefits over a carb are better driveability and fuel mileage.
Old 02-01-2011, 09:59 AM
In some states (CA for instance) adding fuel injection, even if it cleans the car up some, is not legal come smog-check time. Dunno about TN, of course, but just a heads up.
Pat
Just bought 78 Camaro Z28, quesiton on changing 2 barrel carb to 4 barrel Juicer28 Engine 8 06-10-2011 02:47 PM
TBI fuel injector delay??? punk1c5040 Electrical 3 10-23-2004 10:11 PM
Fuel Injector Install Lucky 13 Engine 2 03-08-2004 09:41 AM
Can I replace two barrel carb with four barrel on chevy 305 maverick19642001 Engine 6 02-20-2004 10:00 AM
Two barrel carb maifold with a four barrel on top 73 Nova Guy Engine 10 11-29-2003 08:28 PM
