fuel leak at mechanical pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2013, 05:52 AM
I installed a chrome mechanical pump on my sbc 350. I used 3/8" brake line and ran it from the tank up to the pump. Then I used a braided stainless line and anm fittings to go to the carbs. I sprung a leak at the inlet side of the pump. So i backed it out and used some of the rtv in the white tube. the stuff is actually brown. Tightened it up and the the next day it leaked again. I am thinking that the fitting on the brake line going into the pump inlet is too short and may not be seating properly. Nothing else leaks any where.
Old 02-20-2013, 06:00 AM
Richiehd's Avatar
JS-70
Are you sure that has a seat in it for a brake line double flare? You may have to cut that line, put a pipe fitting, and a short 3/8 hose. Use Teflon tape or paste.
Old 02-20-2013, 06:16 AM
I really am not sure about the seat. I did not want to use rubber, but I guess if that is my only choice. Will teflon tape work with gas? If there is no seat inside the pump then I am assuming that no matter what i do it will still leak, am I correct?
Old 02-20-2013, 06:25 AM
Richiehd's Avatar
JS-70
Teflon will work with gas. If there is no seat in the pump fitting it will be a pipe fitting.
brake line, fuel leaks, inlet, pump
Chevy mechanical fuel pump moving TOO MUCH fuel? Torque454 Engine 1 11-04-2011 01:48 AM
Mechanical fuel pump by (race pump) 66nova383 Engine 2 10-04-2011 07:46 PM
What mechanical Fuel Pump? obengston Engine 11 11-12-2010 12:28 AM
20 year old Carter mechanical fuel pump leak? bubbahotep Engine 8 07-12-2010 04:22 PM
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 01:04 AM
