Fuel leaking from under nozzle in carb - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-24-2013, 11:59 PM
Everything is out in the garage right now, I'll post a pic tomorrow. I actually thought about the crack, but couldn't see one. I'd have to order one online I think. But I'll call around and just maybe I'd luck out. I think its like #31. I think the screw is correct, but again, the exploded diagram is worthless so I can't say 100%, but it looks like what I would expect.
  #17 (permalink)
Old 07-25-2013, 12:05 AM
Yea sometimes u can't see a crack its worth just replacing instead of wasting ur time come to find out that's what it was. If that checks out I may suspect the small check valve/neddle under the squirter I've had mine get stick a few times before and caused a small leak under the squirter
  #18 (permalink)
Old 07-29-2013, 10:45 PM
Just an update, I replaced the nozzel/squirter and it seems to have solved the leaking. But I still am flooding out. I created a new thread for this.
Thanks!
  #19 (permalink)
Old 07-29-2013, 10:54 PM
Glad it worked out and the flooding I would bet its a faulty needle and seat or trash in the needle and seat
The Following User Says Thank You to 78C10 sleeper For This Useful Post:
6T6GTO (07-30-2013)
holley carb leaking fuel onto manifold Jakesf250 Engine 3 07-25-2012 11:12 PM
Leaking carb and fuel pump return line carlk4728 Engine 5 06-16-2012 07:17 AM
quadrajet fuel feeder nozzle? Freddyfingaz83 Engine 6 05-30-2012 01:44 PM
Help with fuel bowl level. Leaking into carb! scapegoat Engine 7 05-28-2008 09:30 AM
Carb fuel rail leaking! frankenvette Engine 2 12-29-2006 10:45 AM
