Fuel Level Sencor - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2011, 10:56 AM
Fuel Level Sencor
I have a custom built fuel tank for my 32 Ford and an looking for a fuel level sencor. The tank has built in baffles to keep the fuel from moving around as much so a lever type unit will not fit. I am looking for the type that has a straight rod with a float that slides up and down as the fuel level changes. I have came a cross some on E-bay that are designed for boats but not sure if I can use them in my car. Any ideas or advice on this. Don't want to blow the car up. Thanks for any help.
Old 04-16-2011, 02:50 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Check out www.wemausa.com
They sell marine senders and gauges for reasonable prices.
If you are using some other brand gauge you will need to know the resistance range (full to empty) so you can order the correct sender.
vicrod
Fuel level gauge question mattson70 Electrical 1 02-23-2007 06:50 PM
mass air flow sencor/map sencor Lil Robert Engine 7 10-03-2005 08:11 AM
Fuel Cell-Tube Type Fuel Level Sending Units Stupido1 Engine 3 06-11-2005 07:31 PM
Fuel float level saenz5 Engine 1 02-11-2004 07:43 PM
fuel level sender?? nova33 Electrical 3 02-08-2004 05:47 PM
