Fuel Line - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2007, 07:31 PM
Fuel Line
Anyone have some advise as how to install a fuel line into a 68 chevelle coupe without removing the body.
Old 02-21-2007, 08:18 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Run it down the inboard side of the frame rail...secure it to the rail good with some brackets .
Old 02-21-2007, 10:08 PM
topdogger's Avatar
Newskool
Last journal entry: New, Used grill arrived!
I'm in the process of doing this on my nova right now. All new steel lines or so I thought I was doing. The back turned out great. Bent the steel tube to match the stock fit. Took about 2 hours first try. When I went to do the front I couldn't get past a point where I had to go all the way around a subframe rail with the body 1 inch above. I ended up wasting over 10 feet of steel tubing. I've decided to run ruber in the front half now.
If you rerun fuel line in the stock location it normally isn't too bad. You can also buy prebent fuel line. The line normally just runs alongside your framerail like Henry Highrise said.
Fuel Line Plumbing leejoy Engine 2 12-31-2005 08:51 AM
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 10:59 PM
efi fuel line sizing / fuel pump Blob Engine 2 09-25-2005 12:25 PM
fuel regulator return line zephyrc Engine 14 09-16-2005 04:56 PM
Designing the fuel system 66Caprice Engine 9 05-12-2005 02:57 PM
