fuel line issues- help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2012, 08:02 PM
i just insalled a new tank lines and filter in my 39 ih and the lines are thermoid fuel line sae30r6u 5/16 and it seems that the lines are turning the fuel orangeish brown. is this bad, will it clog my new carbs, and should i switch out the lines.
thanks for your help
Old 07-24-2012, 10:48 PM
68NovaSS's Avatar
Wiki Edits: 9
I've never heard of that happening, have you talked to the vender you got the lines from?
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 07-25-2012, 06:14 AM
I was going to try to call thecompany today but thought someone maybe has some insight on this
Fuel line kit for Holley 4150 and stock fuel pump colin911 Engine 4 09-13-2011 08:24 PM
Issues with the t/case encoder motor line up after reuild ? old yukon Transmission - Rearend 11 06-04-2011 07:58 PM
Copper Brake Line,Fuel Line redlightning General Rodding Tech 6 08-23-2006 08:50 PM
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 10:59 PM
efi fuel line sizing / fuel pump Blob Engine 2 09-25-2005 12:25 PM
