Fuel line plumbing
Ok, I know there's other posts on this topic but I'm still confused. I have a brand new 383 going into My 74 Nova with a hi-volume mechanical fuel pump. the original fuel system had three lines - one from the tank to the pump (then to carb), a second smaller line from the pump back to the tank. and a third line from the carb to the charcoal cannister and then back to the tank. Which of these lines can I elliminate? My new fuel pump only has provisions for one line from the tank and one to the carb. All original emmisions equip has been removed.
Thanks for the help! |
Before I changed my setup to one with a return line, I was plagued with vapor lock problems. I am using a high volume electric pump, not a mechanical one so I am not sure if the same conditions would exist. |
Ok, so I can loose the charcoal cannister but I should keep the return line with the use of a regulator, right? And this is to make sure that the system can breathe well enough? thanks for the help!
On jeep the return line to the tank is tee-ed out of the fuel filter. This is primarily to prevent any possibility of vapor lock which was a problem on some of those vehicles. You could do this without much trouble.
With a bypass regulator, the excess fuel is just shunted back to the tank keeping it cool and eliminating any possible vapor lock problems. As I said earlier, this is probably more true with a high volume electric pump than a mechanical one because a mechanical pump is tied to engine speed whereas an electric pump puts out the same no matter what the engine speed is. |
[QUOTE=Chris_K]Ok, I know there's other posts on this topic but I'm still confused. I have a brand new 383 going into My 74 Nova with a hi-volume mechanical fuel pump. /QUOTE]
What fuel pump are you using? The pump will only be as good as the supply line will allow, so I would consider replacing the stock line with something larger. |
| Plumbing new fuel system | william27103 | Engine | 13 | 06-24-2005 01:36 PM |
| fuel return line Q | nova 1 kenobi | Engine | 6 | 03-13-2005 05:25 PM |
| fuel line advice needed | mike bryan | Engine | 4 | 12-04-2004 09:14 AM |
| Dual fuel line clearance question. | western star | Engine | 2 | 10-03-2004 04:43 PM |
| Body Line | Man586 | Body - Exterior | 6 | 08-20-2004 08:24 AM |
