fuel line problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2006, 07:35 PM
fuel line problems
I have a 1992 Ford T-Bird 5.0 FI HO. I replaced the in tank fuel pump and started to have problems. Which of the three fuel lines is the pressure, return, ??
Old 06-11-2006, 05:04 AM
RookiePerformance's Avatar
SOLT8KER
bottom of pressure regulator
The return line is the one that comes out of the bottom of the fuel pressure regulator. You need to trace that back to the pump and there ya go. (The pressure regulator looks like a mini EGR valve but it is located on the fuel rail.)
Old 06-11-2006, 05:09 AM
SOLT8KER
The return line is the 5/16th line that comes out of the bottom of the fuel pressure regulator. You need to trace that back to the pump and there ya go. (The pressure regulator looks like a mini EGR valve but it is located on the fuel rail.)
efi fuel line sizing / fuel pump Blob Engine 2 09-25-2005 01:25 PM
Designing the fuel system 66Caprice Engine 9 05-12-2005 03:57 PM
Fuel Injection Fuel Line Plumbing william27103 Engine 0 06-08-2004 11:31 PM
Fuel line question stea Engine 8 06-01-2004 04:59 PM
ford fuel line coupling tool tnoftsger Engine 2 02-18-2004 07:31 PM
