Fuel Line Q - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2004, 04:06 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
Fuel Line Q
I recently converted my 2.8 TBI V-6 S-10 to a carbureted 350. I’m using a Holley “red” fuel pump that sends fuel through the original fuel line to the carb. I’m now left with an unused fuel return line and an unused line that ran to the charcoal canister. What should I do with the two unused lines? Should I just cap them off, connect them to each other, or is there a way to build a “homemade” gas tank vent?
Note: The Holley pump draws fuel through the in tank electric (power disconnected) pump. I am planning to remove the factory pump and replacing it with a fuel line.
Thanks!
Bryan B
Old 07-26-2004, 05:11 AM
Wiki Edits: 49
Cap them. If you ever want to convert your 350 to a TPI unit, you'll need them again.
Centerline
