fuel line recommendations
I AM BUILDING A 55 CHEVY SHOW TRUCK AND WOULD LIKE ADVICE ON WHICH FUEL LINES TO RUN. I MOVED THE TANK TO THE REAR USING CLASSIC PERFORMANCE PRODUCTS ALUMINUM TANK. WAS THINKING OF RUNNING THEM ALONGSIDE THE FRAME RAILS , NOT SURE WHAT WOULD LOOK THE BEST.STAINLESS STEEL,ALUMINUM, CHROME. IS THERE A CERTAIN COMPANY THAT COULD PROVIDE ME WITH EVRYTHING I NEED, FUEL LINES, FITTINGS CLAMPS ETC ANY TIPS OR RECOMMENDATIONS WOULD BE GREATLY APPRECIATED
If it's a true show truck, I would run braided stainless and route them inside the frame rails, being sure to use through the wall fittings to avoid chafing. You can buy hose and AN fittings from JEG's, Summit Racing, Russell, Aeroquip, and many others.
Lose the caps, we can hear ya...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Jegs sells a silver or black powder coated 3/8" OD steel line you should check out. Fuel injection will require a return line which possibly can be smaller.
Then adapt to -08AN (3/8") fittings to run stainless braided flex line to the engine. You need special 37* flaring tool to use AN fittings. Stay away from aluminum tubing for fuel lines. |
| Recent General Rodding Tech posts with photos |
| Who hates NHRA's 12" rubber line rule? | 454headache | Hotrodders' Lounge | 21 | 08-17-2010 07:48 AM |
| Idea for a future big block build | RamAirZ | Engine | 5 | 09-04-2009 05:01 AM |
| Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines | J.J. LASALLE | General Rodding Tech | 6 | 06-29-2009 01:04 AM |
| Octane Booster Info | SLR_65 | Engine | 46 | 09-30-2007 09:01 AM |
| efi fuel line sizing / fuel pump | Blob | Engine | 2 | 09-25-2005 12:25 PM |
