? fuel line restriction - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2006, 01:17 PM
Howdy! Sorry about the double post, but I was hopeing for some quick opinions before I make a mistake. I am pluming my fuel lines today with 5/16" hard line all the way up to the stock pump. There is a large canister style filter as near to the tank as I can get it. I would like to install a fuel shut off valve in line ahead of the filter. The only valve I have found is a compression fitting style that has a very small pass through port (1/16"?). The question is... Is this built in restriction going to give me problems drawing fuel?
Old 08-15-2006, 04:23 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
shutoff valve
1 ea 1/4 inch ball valve
2 ea. 5/16 compression /treaded fittings
2 ea. 5/16 x 1/4 bushings (to adapt the fittings to the valve)
Just a thought. Russ
Old 08-15-2006, 07:23 PM
I took the KISS approach and added a short section of rubber fuel line between the tank and filter. When it comes time to service the filter I'll just clamp it off. But... thanks for your reply!
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 10:59 PM
efi fuel line sizing / fuel pump Blob Engine 2 09-25-2005 12:25 PM
fuel regulator return line zephyrc Engine 14 09-16-2005 04:56 PM
Fuel Line Vent jcdaly Engine 1 02-19-2005 09:07 PM
Holley Street Avenger Fuel Line western star Engine 5 12-30-2003 09:25 AM
