Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - On Fuel lines...
Old 05-02-2010, 12:50 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
That is what is called the metric bubble flare, or maybe metric ISO flare, I can't remember which its called at the moment. They will not seal if you re-flare to 45 or 37 flare unless you also change whatever fitting they screw into to match the new flare type.
Your current fitting makes a double seal, to the bottom of the step at the fitting and at the top of the step to the nut.
