-   -   On Fuel lines... (http://www.hotrodders.com/forum/fuel-lines-177226.html)
unstable 05-02-2010 11:17 AM
On Fuel lines...
-Had a gas leak.
-Lines looked really nasty as did the filter.
-Dropped tank.
-Decided to replace lines while I have access to them.
Removed steel lines from fuel filter and flexible steel line to hard-steel line to bypass/tank...said fittings look like this:
http://img203.imageshack.us/img203/1...ngmay22010.jpg
For some stupid reason I was expecting 45 degree flares...
The fuel system is TBI.
Can I use regular steel line and put a 45 degree flare on it and will it hold or do I need to do something else? This existing system had o-ring and other crap...maaaan.
suggestions? I really don't want to pay $50 million dollars for these stupid steel lines and have to wait a week to get them.
ericnova72 05-02-2010 11:50 AM
That is what is called the metric bubble flare, or maybe metric ISO flare, I can't remember which its called at the moment. They will not seal if you re-flare to 45 or 37 flare unless you also change whatever fitting they screw into to match the new flare type.
Your current fitting makes a double seal, to the bottom of the step at the fitting and at the top of the step to the nut.
unstable 05-02-2010 01:47 PM
that is not-excellent, most non-triumphant, and most of all bogus...It was probably around the time that everyone could get their hands on a standard flaring kit that they switched over to metric. weak.
Thanks for the info.
