Fuel lines on a '77 chevy 2500 pick up ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2007, 08:58 PM
Old School Baja's Avatar
The only tie I ever wear...
Hey gang, I'm hard pressed to get my work truck going tonite.
My return line was leaking and I need to replace it. Can I substitute 5/16" for 1/4"?
Has anyone ever done this?
I'm out of 1/4", but I have plenty of 5/16"
Or should I wait and get the exact size?
Thanks, Ryan.
Old 06-22-2007, 10:00 PM
Jmark's Avatar
Hi Ryan.
If that's all you have, it should be fine. It's not a high pressure line anyway, it's the return line. The inlet side is 3/8"s. Just make sure you use clamps to squeeze it down if it's loose on the fittings.
Mark
Another '77 owner.
Old 06-22-2007, 10:37 PM
Originally Posted by Jmark
Hi Ryan.
Mark
Another '77 owner.
Thanks Mark!~
65 chevy fuel pump - 6 cyl sabino56 Engine 6 09-04-2005 11:03 PM
50 chevy pu fuel tank options fat50chevy General Rodding Tech 4 09-03-2005 03:35 PM
Replacing fuel and brake lines adb2f General Rodding Tech 4 11-25-2003 10:29 AM
Fuel lines Tom S Engine 6 07-29-2003 06:30 PM
92 chevy pickup with 383 (timing & fuel ?s) dunegoon Engine 2 12-11-2002 09:12 PM
