-   -   Fuel lines that last (http://www.hotrodders.com/forum/fuel-lines-last-226203.html)
spinn 11-17-2012 02:07 PM
If you run your own fuel lines what do you use? Most hotrods are built beyond the 5/16-3/8" metal prebent lines that are remade very well in SS. Not a racer but always keep the rubber line joining parts inches at best. My builds have used long oversized prebent SS lines from tank to pump. The melling mechanical 110gph pump is -6 an a small rubber link is a joint between the tank sender and tank line , then tank line and pump inlet. After the inlet it is -6 AN braided lines that are rubber insides. Braided all the way to the the carb no rubber there. Never had leaks. Are braided compareable to SS tubing?
What are is the longevity of that system. The SS tube I anticipate no problem. The Braided rubber center line has me guess?ng?
One system has been in place sealed no leaks for 12 years.
Richiehd 11-17-2012 02:23 PM
Ive got stainless braided on my Skiff, no issues for many years. I understand Methanol will eat them on the inside, but so far no issues.
gearheadslife 11-17-2012 05:28 PM
never rust, and easier to work than s/s and cheaper
AGS Company - NiCopp Products
1971BB427 11-18-2012 10:49 AM
I use steel, but not SS. Rust isn't a big issue where I live, so steel lasts forever. My '71 still has it's original steel lines.
Pantaz 11-19-2012 02:47 PM
Originally Posted by spinn (Post 1612383)
... Are braided compareable to SS tubing? ...
No. The stainless steel braid covers only the outside, the inside is rubber*. I believe CPE (chlorinated polyethylene) is the lining recommended for alcohol fuels.
* There are many types of s/s braided hose made with a variety of materials for compatibility with different fluids, temperatures, and pressures.
